DavidSL
Feb 23, 2017Aspirant
Is there a certificate of volatility available for the JGS524V2
DaneA
Feb 26, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to download the certificate of volatility for the JGS524v2 on the link provided?
DaneA
NETGEAR Community Team
- DavidSLFeb 27, 2017Aspirant
Yes, the download was successful, Thank you
- DaneAFeb 27, 2017NETGEAR Employee Retired
Thanks for the feedback. I'm glad to know that you were able to download the certificate of volatility for the JGS524v2 switch. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
