HenryvS's avatar
HenryvS
JGS524 3D CAD file
Hi there,   I'm looking for a 3D CAD file of the JGS524V2 switch to design it into a machine where the switch must be fix on a bottom plate. To design the brackets i need a 3D CAD file. I've look...
  • DaneA's avatar
    May 31, 2021
    HenryvS,
    Welcome to the community! :)
    I'm sorry to inform you that there is no 3D CAD file of the JGS524v2 switch.
    You may want to check out the Visio Stencil for the JGS524v2 switch here.  Be reminded that there is a subscription required.
    DaneA
    NETGEAR Community Team
ProSupport for Business
