JediDavs's avatar
JediDavs
Follower
Jan 08, 2018
Prosafe GS105Ev2 CAD Drawing Request
Hi There!
I need an External CAD drawing for this switch to speed up the design process. Can anybody assist??
Thank you in advance for your support.
  • Hi JediDavs,
    Welcome to the community! :)
    As far as I have checked, there is no CAD Drawings available for NETGEAR ProSAFE devices.  However, there are NETGEAR Visio Stencils that you can download here.  Kindly check if the GS105Ev2 switch is included in the Visio Stencils as I do not have Microsoft Visio installed here on my end.  Then, if ever there is a GS105Ev2 switch is included in the Visio Stencils, use it as reference in making a CAD drawing for it.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi JediDavs,
    DaneA
    • DaneA's avatar
      DaneA
      JediDavs,
      I just want to follow-up on this.  Let us know if you have further inquiries.
      Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      Cheers,
      DaneA
ProSupport for Business
