JediDavs
Jan 08, 2018Follower
Prosafe GS105Ev2 CAD Drawing Request
Hi There! I need an External CAD drawing for this switch to speed up the design process. Can anybody assist?? Thank you in advance for your support.
- Jan 09, 2018
Hi JediDavs,
Welcome to the community! :)
As far as I have checked, there is no CAD Drawings available for NETGEAR ProSAFE devices. However, there are NETGEAR Visio Stencils that you can download here. Kindly check if the GS105Ev2 switch is included in the Visio Stencils as I do not have Microsoft Visio installed here on my end. Then, if ever there is a GS105Ev2 switch is included in the Visio Stencils, use it as reference in making a CAD drawing for it.
DaneA
NETGEAR Community Team
DaneA
Jan 09, 2018NETGEAR Employee Retired
Hi JediDavs,
DaneA
DaneA
Jan 14, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
