DominikHoffmann's avatar
Feb 13, 2024
Differences in specs of GS324 and JGS524
There are two 24-port unmanaged gigabit switches (at least): The GS324 is gray and a little narrower than the JGS524, which is blue. What are the real technical differences of the two? On Amazon the GS324 sells for $90, whereas the JGS524 sells for $130. I guess, in other words my questions is, what does that $40 difference by me in the JGS524 that the GS324 doesn’t have?
  • JGS524 is about two generations older, functional are both unmanaged GbE switches. Remains just the exact warranty terns to compare.
1 Reply
  • schumaku's avatar
    schumaku
ProSupport for Business
