HenryvS's avatar
HenryvS
JGS524 3D CAD file
Hi there,
I'm looking for a 3D CAD file of the JGS524V2 switch to design it into a machine where the switch must be fix on a bottom plate.
To design the brackets i need a 3D CAD file.
I've looked a lot but cannot find anything.
https://www.netgear.com/support/product/JFS524v2.aspx
Friendly regards
Henry
  • HenryvS,
    Welcome to the community! :)
    I'm sorry to inform you that there is no 3D CAD file of the JGS524v2 switch.
    You may want to check out the Visio Stencil for the JGS524v2 switch here.  Be reminded that there is a subscription required.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    HenryvS,
    DaneA
    • HenryvS's avatar
      HenryvS
      Hi,
      Thanks for the clear answer. So i do not have to look further. ;)
      I will measure the device screw holes and make a simple 3D model for designing the brackets.
      Best regards.
      Henry
ProSupport for Business
