HenryvS
May 31, 2021Aspirant
JGS524 3D CAD file
Hi there, I'm looking for a 3D CAD file of the JGS524V2 switch to design it into a machine where the switch must be fix on a bottom plate. To design the brackets i need a 3D CAD file. I've look...
DaneA
May 31, 2021NETGEAR Employee Retired
Welcome to the community! :)
I'm sorry to inform you that there is no 3D CAD file of the JGS524v2 switch.
You may want to check out the Visio Stencil for the JGS524v2 switch here. Be reminded that there is a subscription required.
DaneA
NETGEAR Community Team
HenryvS
Hi,
Thanks for the clear answer. So i do not have to look further. ;)
I will measure the device screw holes and make a simple 3D model for designing the brackets.
Best regards.
Henry
