kenchen_aruba's avatar
Dec 18, 2020
JGS524 ECCN and CCATS
Hi,
Can someone please provide the following information for JGS524? I need it to ship outside of the US.
US ECCN
CCATS
HTS Code
Does this Switch operate on Layer 3? If not, what layer does the switch operate on?
Does this Switch have/use MIMO technology?
Does this Switch use in ISP/TSP?
Does this Switch have/use SIMO technology?
Thanks
Ken @ Aruba HPE
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    kenchen_aruba,
    Welcome to the community! :)
    US ECCN
    CCATS
    HTS Code
    About the US ECCN, CCATS and HTS Code, kindly access and read the link below:
    US Customs Compliance
    The JGS524 is a Layer 2 switch.
    Both MIMO (Multiple-Input Multiple-Output) and SIMO (Single Input, Multiple Output) are for wireless communications and therefore NOT supported by the JGS524 switch.
    If you need to extend your LAN, you will need the JGS524 to connect more devices hardwired like PC, network printer, etc.  Be reminded that the recommended setup would be: modem-router-JGS524.  You will need an ISP subscription so that you can have internet access.  The JGS524 does not support TSP.
    The latest JGS524 switch model is the JGS524v2 (v = version).  To know more about its specifications, kindly check its data sheet here.
    DaneA
    NETGEAR Community Team
    • kenchen_aruba's avatar
      kenchen_aruba
      Hi DaneA,
      Thanks for the reply.
      I looked at US Customs Compliance, I see several ECCNs listed, which one do I use for JGS524?
      Also, I don't see HTS or CCATS mentioned.
      Thanks
      Ken
      • schumaku's avatar
        schumaku
        Model Number - Description - Line - ECCN # - Import HTS - Export Schedule - CCATS#
        JGS524 - 24 port Gigabit Ethernet Switches - Switch - 5A991 - 8517.62.0050 - 8517.62.0050 - G044731
ProSupport for Business
