notanetworktech
Nov 29, 2016Aspirant
Letters of Volatility
Can someone please provide letters of volatility for a GS105 and JGS516 switches? Thanks in advance!
- Nov 29, 2016
Hi notanetworktech,
You may download the letter of volatility of the GS105v4 and JGS516v1 on the links below respectively. The links will expire within 1-2 days.
If you will need to request the letter of volatilty for other versions of the switches mentioned, you may just reply on this forum thread.
DaneA
NETGEAR Community Team
DaneA
Nov 29, 2016NETGEAR Employee Retired
Hi notanetworktech,
Welcome to the community! :)
The GS105 has 5 versions (GS105v1, GS105v2 and so on) and JGS516 has 2 versions (JGS516v1 and JGS516v2). What specific version of the switches are you referring to?
DaneA
- notanetworktechNov 29, 2016Aspirant
Hi DaneA,
GS105V4 and JGS516V1 at this moment. Is there somewhere I could retrieve them if I'd like other versions? Or should I open a new discussion for future requests?
Thanks!
Gabe
- DaneANov 29, 2016NETGEAR Employee Retired
Hi notanetworktech,
DaneA
- JohnRoDec 02, 2016NETGEAR Employee Retired
Hi notanetworktech,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- HodgeGoblinDec 21, 2016Aspirant
Could I also get the copy of the Letter of Volatility for the JGS524NA?
Also, Is there a way to have these LOV added to a repository or something with a more static link? Then someone won't have to dig through the forum clicking on links to LOVs in solved threads just to find them all expired.
Thank you,
H
