mamezcua8201
May 06, 2024Aspirant
looking for recommendations on switches compatible with rs700 and cax80
I am trying to get into hard wiring everything for my gaming setup and I would like a switch, possibly managed to be able to experiment with networking, but i am kind of confused on what would be com...
May 07, 2024Guru - Experienced User
If it was me? I'd pickup a cheap multigig non-managed switch and a managed used switch.
then you can hardwire in your gaming devices directly on the non-managed multigig switch.
You can hookup the managed one after and experiment a little. some of the managed functions can add latency so putting it after and playing with a cheap used one might be a better option until you're more familar with its useage.
mamezcua8201
May 07, 2024Aspirant
Thank you i see your point in that i am dealing with latency and packet loss already over wifi so this led me down this road but i will look into that for sure!
- schumakuMay 09, 2024Guru - Experienced User
Even the best, most expensive, fastest, ... managed, smart managed, or unmanaged, whatever brand of switch, there are a zillions of reasons why packet loss and latency are occurring. Not many reasons why a random wired Ethernet switch should be compatible. Even worse on a shared media - as the air is for wireless. At the end of the day, it depends what you want to achieve, what you expect, what features you need.
- michaelkenwardMay 09, 2024Guru - Experienced UserAnd how much you want to pay.
