zayemm0b
Dec 01, 2023Follower
Model GS316PP.
I need to know how to connect to router. The cable coming out of the router should go to which one out of 16.
After that do I need to program the device or it will work automatically
1 Reply
The GS316PP is an unmanaged switch, all plug-and-play. Any port can be used for the uplink to the router LAN port.
Don't hesitate to consult the 16-port Gigabit Ethernet Unmanaged Hi-Power PoE+ Switch with FlexPoE Installation Guide for more information.
Because the GS316PP isn't a Nighthawk Wi-Fi 5 (AC) Router, I'll request a moderator to move your post to the Unmanaged Switches Forum community section.
