SKYMASTER69
Feb 28, 2024Follower
UNMANAGED GS316PP
Hi all,
I am trying to find out if this switch GS316PP, is effectively and active or passive switch?
I realise all the ports are POE+.
1) Can I connect any device to it wether they need 1W or 30W?
2) and can I connect devices that do not need power at all/not POE compatible? such a printer or land adaptor for a computer etc?
Thank so much for clarifying!
1 Reply
Yes, you can - perfectly safe. The total amount of PoE powered devices is limited by the number of ports, and the total power available on your switch model variant - these exist with
Power adapter model Power adapter Total power budget
EPS90W 90W, maximum power budget 76W
EPS130W 130W, maximum power budget 115W
EPS200W 200W, maximum power budget 183WThe slider on the switch back side is just to "program" the power management for notifying in a possible power overload.
Yes, absolutely. This is possible thanks to Netgear not making Passive PoE switches - it's all well defined in the IEEE standards. A device (like a computer, printer or a wireless access point), potentially PoE powered, does negotiate the "need" for PoE power. Without requesting the right power, these are just plain normal Ethernet ports. Nothing to worry at all.
Welcome to the Netgear Community!
