Sylwedydd
Jan 03, 2017Aspirant
Model Identification of JGS524 Series Switch
Hello, I have decided on the JS524 Switch for my network. In my pursuit I have seen a Model JGS524 V1. On your site there is no reference to it, only the JGS524 V2. Is the V1 a "knockoff" or mere...
- Jan 05, 2017
I did a research about the JGS524v1 data sheet online. If ever you are still curious about it, you can download it here and you can also view it here.
For the JGS524v2 data sheet, you can download it here.
Here is a quick view of the differences between JGS524v1 and JGS524v2:
From the table above, it is advisable that you get the JGS524v2 instead of the JGS524v1.
Regards,DaneA
NETGEAR Community Team
DaneA
Jan 03, 2017NETGEAR Employee Retired
Hi Sylwedydd,
Welcome to the community! :)
The JGS524v1 was already discontinued by NETGEAR. I also cannot find any information about the JGS524v1. If ever I find any information, I will post it on this thread.
I recommend you the JGS524v2 since this is the one that is available in the market and this is an enhancement of the JGS524v1.
DaneA
Sylwedydd
Jan 05, 2017Aspirant
Thank you
- DaneAJan 05, 2017NETGEAR Employee Retired
Regards,DaneA
- SylwedyddJan 05, 2017Aspirant
Thank you Dane. Big difference
- DaneAJan 08, 2017NETGEAR Employee Retired
You're welcome. :)
Since your concern has been answered, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
