RedBullet's avatar
Oct 03, 2018
Model Identification of JGS524 Series Switch
I haave a JGS524 unmanaged switch. I'm trying to find some technical specs on it, but I see two over versions of this, v1 & v2.
I assume mine is NOT the v2, but is it the v1? or something else?
And where can I find the specs on it?
(I suspect it is a tad old, and it might be worth upgrading to newer version?)
Thanks in advanc3!
  • Hi RedBullet,
    If you have the JGS524 switch model, it means that you have the JGS524v1 (v = version).
    Here below are the differences between JGS524v1 and JGS524v2 switches:
    To know more about the JGS524v1 switch, check its datasheet here.
    For more information about the JGS524v2 switch, check its datasheet here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi RedBullet,
    DaneA
  • schumaku's avatar
    schumaku
    Checkt the product label model information:
    JGS524-100xxx (like JGS524-100EUS) == v1.
    JGS524-200xxx (like JGS524-200EUS) == v2.
    • RedBullet's avatar
      RedBullet
      Tutor
      Thanks for the replies. I probably can't take advantage of jumbo frames. So, aside from that anyone think it would be worth upgrading to v2?
      Or perhaps a different unmanaged switch?
      Thanks, appreciate the feedback and opinions.
      • DaneA's avatar
        DaneA
        RedBullet,
        For me, if ever your current JGS524 switch is not giving you any problems which means its still working fine, I suggest you to stick with it in order to avoid unnecessary cost.
        Let me share the link below where you can select the switch that matches your network requirements:
        NETGEAR Switch Selector
        DaneA
