sethjlamb90
Apr 09, 2025Aspirant
MS105 halving download speeds
Hi everyone, I'm posting this under Nighthawk Gaming Switches because there doesn't appear to be a general switches board. Also I'm used to lurking on boards like this looking for answers so this...
Apr 10, 2025Guru - Experienced User
So if you disconnect the older 24 port switch from the MS switch and just test with a ethernet connected device at the MS switch, speeds are still not good?
Try a different ethernet connected PC to compare results.
What CAT# LAN cable are you using between the ISP router and the MS switch? CAT6A STP would be suggested to try.
sethjlamb90
Apr 10, 2025Aspirant
Thanks for the reply. Essentially the answer to your first question is yes. In order to isolate the MS unit, I did just test it directly connected to the ISP router, and then jump from it to my computer. I'm using brand new 6' CAT6 patch cables by Cable Matters ordered from Amazon. They are rated for 10GBe. Speeds with this setup are 500-900MB on the download but 1700-1900MB on the upload.
Note that if I connect directly to the ISP router with the same cables, I'm getting 1900MB up and down.
Most everyone in the office has Surface laptops now, so while I can technically use a different computer, I would still be using the same USB C adapter. I'll see if I can think of a different solution for that though.
Is it possible this MS105 is defective?
- FURRYe38Apr 10, 2025Guru - Experienced User
Possible. Would need to try another one or something else with same specs to check that.
