Mandrew373's avatar
Mandrew373
RAX 120 Slow Download speeds
I have been having an ongoing issue with download speeds on my RAX 120. I factory reset the modem already, firmware is up to date, QOS is turned off. For about a day I got normal download speeds(usually 600-700mbps with my internet provider), and then it throttles down to about 90mbps. If I unplug the modem and router for 5ish mins, then plug them back in(waiting to plug the router in until the modem is fully online), speeds go back to normal for a couple of hours, then go back to 90mbps down. I called my ISP and they see no issues on their side, firmware is up to date on the modem. I tried calling netgear, and because I’ve had my modem for a few years, they refuse to help me unless I pay. Anyone have any ideas?
  • Welp, I feel like an idiot now. I replaced the Ethernet cable that ran from the modem to the router and my speeds are running consistently around 660mbps. Been that way for a few hours now.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How is the RAX connected to the ISP modem? Using the Yellow WAN port or do you have the multi gig port configured to connect to the ISP modem?
    What brand and model ethernet device do you have connected?
    Same thing happens across other ethernet devices?
    Armor, Smart Parental Controls or Circle, Traffic Meter.
  • Don’t have anything I can connect via Ethernet to the modem unfortunately. My work laptop is the only thing I have that has an Ethernet port, and the block basically all outside websites. There’s only the coax in from Sparklight, and an Ethernet out port. Are we thinking the Ethernet cable is the issue?
    • FURRYe38's avatar
      Speed testing with the TV won't give good results as the TV only supports 100Mpbs and won't see past this.
      You'll need to get a ethernet connected PC that supports 1000Mpbs to check what your really getting while connected to the router, or you can also directly connect to the CM series modem to check there as well.
      I see you have MIMO enabled which is good.
      What Basic Wireless Settings are configured on the RAX router?
      If you can post the CM modems cable connections and event logs as well here.
    • FURRYe38's avatar
      Cables can be problematic if not made well. Glad that was it if that's the case.
      I get good cabling from places like monoprice and deepsurplus.
      Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
      Enjoy. 📡
