KROMINATOR
Jan 18, 2024Aspirant
Need help with new 5 port switch
I bought a Net Gear 5 port switch so I can get internet to all four of my tvs......I have an ethernet cable running from my router in the basement to the switch in our bedroom......From there I have ...
schumaku
Jan 19, 2024Guru - Experienced User
KROMINATOR wrote:
I bought a Net Gear 5 port switch so I can get internet to all four of my tvs......I have an ethernet cable running from my router in the basement to the switch in our bedroom......From there I have run four ethernet cables to each room in the house to be connected to the txs......I tested the cable from the router to switch and it passed.......I tested the cables from the switch to the tvs and they have passed......When I connect everything and power up the switch, I can not connect to the internet........
Let's start with the very basics. Where is the switch connected to? In case this is a pure Cable Modem or a building-operated Internet access port (not a router for connecting multiple devices to a network), most ISP only allow one device and assign on IP address only. This is the typical problem leading to the situation that only one device (TV here) can connect to the Internet. Solution is adding a basic router, which does the NAT (Network Address Translation) and sometimes has a wireless access point built-in to give you the option for connecting e.g. your mobile to the same network.
Great you have invested in a cable tester for testing the installation, this indeed often helps finding the basic layer one cabling issues.
So I unplug the switch and test the ethernet cables connected from the basement to the switch and then on to the tvs and it fails the test stating a short.......Does the switch have to be powered up for the cables to pass a test?......The tester warns against testing with power to the ethernet cables........
Most testers come with two devices, a test head, and a remote plug. For testing, both ends must be unplugged from switch and TV. Both the remote plug and the test head must be connected to the same cable to do a proper test.
The warning is correct: Never connect and active just the test unit to a cable connected on the other end to a switch, a router, a computer, ... No useful result can be taken from the measurement. The reason that the tester show a short circuit is in the way Ethernet works: Each cable pair is terminated on a tiny transformer, similar to the design of a classic (non-switching design) low voltage adapter for chargers or electronics power supplies.
KROMINATOR
Jan 19, 2024Aspirant
We just had fiber optics installed and I believe they use a combination modem/router.....I ran an ethernet cable from that device to a net gear gs105 switch located in the bedroom......I ran an ethernet cable from the switch to a TV......The switch and the modem/router are communicating and all lights on that port are on......
no lights are showing on the port to the TV and I can not connect to internet.....I tested all cables by unplugging the ends and connecting the remote on one side of cable and the tester on the other.......Cables all passed......The switch is brand new as well but is there an easy way to test it......I also tried installing a downloaded update that the TV recommended but that did not work......I really appreciate your reply because I am at a loss here.....Thank you.
- schumakuJan 19, 2024Guru - Experienced User
Sounds reasonable, good infrastructure testing 8-)
Tell us more about this CPE, the ISP, ... in absence of a crystal ball please.
- KROMINATORJan 19, 2024Aspirant
ISP is Frontier Communications who ran fiber optics into an ONT and then into the modem/router which has no name or markings that I can see other than their name.....I am assuming that CPE is referring to equipment that I attached.....I am a little illiterate with these types of electronics so please forgive my ignorance.......Switch is a Net Gear GS105v5 5 port unmanaged switch and the TV is a Westinghouse WR43UX4210 Roku TV.......I am completely lost about the crystal ball reference other than I wish I had one to find out what the problem is....
An ONT is a Optical Network Terminal box, converting from fiber to copper. While it's an Ethernet connection, there is some router connection required - being for authentication to the network, being for connecting a LAN, being for connecting wireless devices. Just the ONT and a switch isn't enough I'm afraid.
A CPE is a Customer Premise Equipment device is typically much more.
