grups's avatar
grups
Follower
May 29, 2018
Need Letters or Volatility for several products
Hi,
I'm looking for LOVs for the following items:
DS104
JFS516
JGS516
Thanks in advance for your help.
Grups
  • grups,
    Just a follow-up on this.  Were you able to download the Letter of Volatility of the JFS516 & JGS516 switches?
    If ever you were able to download it and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi grups,
    Welcome to the community! :)
    The DS108 hub is already EOL (End-of Life) which means its not being manufactured anymore.
    For the Letter of Volatility for JFS516 and JGS516 switches, click on the the download links respectively below:
    JFS516 Letter of Volatility
    JGS516 Letter of Volatility
    DaneA
  • DaneA's avatar
    DaneA
    grups,
    DaneA
ProSupport for Business
