wla
Jul 16, 2018Follower
Negear ProSafe GS108PE - multiple 802.1q vlan on 1 port
Hi, I'm searching for little (and cheap) switch for our network. On ports 1 to 3 we'll attach wifi access points with multiple ssid's. Each ssid has it's own vlan. on the other will be pc's in ano...
- Jul 17, 2018
Hi wla,
Welcome to our community! :)
GS108PE is one of our Prosafe Plus switches that supports VLAN. If you do have a VLAN aware router then you may try the steps below:
- Connect your computer to the same network as the switch.
- Double-click the ProSAFE Plus Utility icon. (Install the utility just in case you haven't done it)
- Create VLAN 111, 112, 113 and 114
- Select VLAN > 802.1Q > Advanced > VLAN Membership
- Assign the ports to its corresponding VLAN.
T / Tagged / Trunk is only for VLAN aware devices such as router, access points, switch, VOIP, etc.
U / Untagged / Access ports are only for non-VLAN aware devices such as printers, scanners, computer, etc.
VLAN 111, 112 and 113 (Access points with multiple SSIDs)
Port 1-3 - T or Tagged - PVID 1
Port 8 - T - PVID 1 (Uplink to router)
VLAN 114
Ports 4-7 - U - PVID 114
Just let me know if you have questions.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jul 17, 2018NETGEAR Employee Retired
Hi wla,
VLAN 114
- May 25, 2022Retired_Member
