Bret4312
Nov 02, 2015Aspirant
Netgear FS116 Switch not connecting
Hi All; Tonight i traded in my older modem (ISP provided) which was connected to a D-Link router then to the Netgear FS116 switch. The new modem/router replaces both those and is a Cisco DPC3848...
- Nov 04, 2015
Hi Bret4312,
Bret4312 wrote:
"I see" said the blind man.
Thanks Dane - you're a good man. I will try my luck with Netgear support. Of course, I have no invoice.In the absence of the Proof of Purchase or Sales Invoice of the FS116, alternatively you may provide the following:
1. An e-mail from the reseller for confirmation of sale.
2. Credit card statement showing the purchase of the device.
Bret4312 wrote:
Presuming these machines have a life and this is not uncommon, would you expect the simple act of an unplug/plug would kill the unit? It worked fine in the moments up to that act.For me, a simple act of an unplug/plug should not cause the switch to be faulty. Unless, there is really a problem or fault with the hardware itself or with the power adapter that is being used with the switch.
DaneA
NETGEAR Comunity Team
Bret4312
Nov 04, 2015Aspirant
Thanks
Thanks
- DaneANov 04, 2015NETGEAR Employee Retired
Hi Bret4312,
DaneA
- hozzanatorNov 25, 2015Aspirant
Dude, did you accidentally plug the PSU from the old router into the FS116 instead of the actual PSU for the FS116 - I did this once and the power rating for the wrong PSU let the switch light up but it wouldn't work!
