daro346's avatar
daro346
Follower
Nov 21, 2015
Netgear FS205 drops offline
I am using a netgear fs205 as a switch.  I am connecting a few devices to my network.  The network keeps dropping offline.  when I connect to a different switch or directly to the router, the problem...
  • ElaineM's avatar
    Nov 24, 2015
    Welcome to the community, daro346 Just to be sure, did you try using a different ethernet cable?
    If it's the same, I suggest that you get a replacement.
ProSupport for Business
