eberhard223
Nov 26, 2022Aspirant
netgear gs116pp stops working all 24 hours
hi, am having a strange problem with my NETGEAR GS116PP PoE switch: - After ~2 years, it stops working approximately the same time in the evening and stops channeling traffic - Still, all ...
schumaku
May 24, 2025Guru - Experienced User
As a moderator indicated earlier in ths thread, head to https://my.netgear.com/ , click on registered product, and follow the [Request Hardware Support].
eberhard223 never mentioned why he was under the impression his GS116PP is not under the limited lifetime hardware warranty. TP Link unmanaged switches come (to my knowledge) not similar this generous warranty terms.
eberhard223
May 24, 2025Aspirant
Well, 1) It was the 2nd device of this kind, which failed. 2) These kind of devices are normally a long time in a rack and expected to work without problems. So, even if there is warranty, it is cumbersome and creates friction. And 3) The mentioned lifetime hardware warranty process is also a cumbersome one. - Generous or not, I like devices which work as intended.
