BPesce
Jun 20, 2023Aspirant
NetGear GS250V2 unmanaged switch not working?
There’s only one ethernet (RJ45) receptacle in our small conference room so I bought a NetGear GS205v2 unmanaged switch in order to connect both the VOIP phone and the new LG smart TV to the ethernet...
schumaku
Jun 20, 2023Guru - Experienced User
BPesce wrote:
I did this to secure our new smart TV, wired being more secure than WiFi.
Makes perfect sense to deploy a switch in this network position. Wired Ethernet is much more reliable and performing usually better.
BPesce wrote:
The green lights on the switch lit up but the phone wasn’t connected to the internet and couldn’t make calls. When I connected the phone’s cat cable back to the ethernet receptacle it started working again.
Hard to say what happens there.
All three ports connected (the uplink to the server room, the VoIP phone, the Smart TV show active links as you said.
Can you figure out what could be special on the network port from/to the server room? Different VLAN, or port security in place?
BPesce wrote:
This particular device doesn’t appear to have a dedicated uplink port.
Correct, there is no dedicated uplink port - all ports are equal.
BPesce
Jun 28, 2023Aspirant
06/28/2023
Thank you for your responses Schumaku, greatly appreciated.
It appears that our VOIP phones might be set up in a VLAN although I wasn't able to confirm that. Another employee with a lot of technical knowledge plugged the smart TV's ethernet cable into the VOIP phone's spare RJ45 port (I wasn't even aware that the phone had one). We confirmed the wired ethernet connection via settings. This was a simple and cost-free solution. In the future if we have need to wire in other devices, I'll connect the switch between the phone and the TV and see if that works.
Thanks again. Bernadette Pesce
