TheThinking
Apr 21, 2025Follower
NetGear S350 GS308 not working LED ports light green when nothing is plugged in
I have had this NetGear GS308 unmanaged switch for over a year now. All of a sudden it stopped working at the port 1, 6,7, and 8 lights are solid green. I tried to reset the device, but no luck in connectivity. I searched the boards and the web, there’s no indication what the lights means when nothing is plugged in.
Any help would be greatly appreciated.
Thanks!
1 Reply
Some LED Info: https://www.downloads.netgear.com/files/GDC/GS308/GS308_Combined_EN_IG_11Jan2013.pdf
If the switch doesn't seem to return to a good ready state after being unplugged from the power adapter and these ports are not working any more, might just get a new one. There fairly easy to find online and fairly inexpensive. I found one on shopgoodwill.
