netcora
Aug 20, 2025Guide
Netgear XS508M/Router GT-BE98 Pro Slow with one Intel NUC
Hello. I have the switcher XS508M its LAN Port 1 is connected to the Lan Port 10G port of my router GT-BE98 Pro, and the NUC is connected to LAN Port 2 of the XS508M in other words, in switch XS508M ...
Aug 22, 2025Guru - Experienced User
netcora wrote: Netgear XS508M/Router GT-BE98 Pro Slow with one Intel NUC
You seem to be assuming that the problem is with the XS508M->NUC connection. I am thinking it might well be the router->switch path.
Are you seeing both LEDs lit green on the switch for both 10G connections?
- https://www.downloads.netgear.com/files/GDC/XS505M/XS505M_XS508M_IG_EN.pdf
netcora wrote:For example in one MYQ Garage opener if I connect to the Switch
I am confused on this, since the MYQ garage opener I see on line only supports wifi connections.
