netcora
Aug 20, 2025Guide
Netgear XS508M/Router GT-BE98 Pro Slow with one Intel NUC
Hello. I have the switcher XS508M its LAN Port 1 is connected to the Lan Port 10G port of my router GT-BE98 Pro, and the NUC is connected to LAN Port 2 of the XS508M in other words, in switch XS508M ...
netcora
Aug 21, 2025Guide
Hello. Thank you for the prompt reply. The NUC I tested is
NUC13ANHi7000 but as I said if I connect to the switch less speed than connected directly to the router and even connecting directly to the router in 2.5 port is extremely great, but in the switch not.
I'm using CAT 8 cable, but is not supposed if the router is perfect the connection with such cable the switch should be do the same?
This si the network card of the NUC
C:\Users\INTELNUC>wmic nic where "NetEnabled='true'" get Name, Speed
Name Speed
Intel(R) Ethernet Controller I226-V 2500000000
I see 2.5 then should work.
And for other devices then if is 1Gb is suggested use used another switch over this switch becuase as I explained the MYQ Liftmaster device a gate opener is not recognized at all and only is detected directly from router.
Aug 22, 2025Guru - Experienced User
Happen to have another PC with high speed card installed? If so, something to try and test out with the switch, Connect both PCs to the switch and install iPerf or something you can speed test the data flow between these two PCs when connected with the switch in the middle and see if speed is slow between them or not. Would be telling.
Be sure drivers are up to date for the Intel ethernet card as well.
I see other have noticed some issues with this particular model card: https://www.reddit.com/r/intel/comments/123kjuc/anyone_else_still_having_issues_with_i226v
netcora wrote:Hello. Thank you for the prompt reply. The NUC I tested is
Name Speed
