netcora
Aug 20, 2025Guide
Netgear XS508M/Router GT-BE98 Pro Slow with one Intel NUC
Hello. I have the switcher XS508M its LAN Port 1 is connected to the Lan Port 10G port of my router GT-BE98 Pro, and the NUC is connected to LAN Port 2 of the XS508M in other words, in switch XS508M ...
netcora
Aug 23, 2025Guide
Exactly FURRYe38 I noted some strange behavior in the switcher.
I made some tests in the router to make some DHCP IP's static with macid and normal things and suddenly the switcher again started to give half of speed and if I connect the devices directly to the router they are at maximum. Is there a special condition or something that makes the switcher low the speed? Now, again I'm trying to make it behave with high speed. The interesting is the leds are green in all portals as normal. The only thing I did is remove the king aggregator from the Bios and assign some IP's to some devices and that's all.
Aug 24, 2025Guru - Experienced User
netcora wrote:The only thing I did is remove the king aggregator from the Bios and assign some IP's to some devices and that's all.
Maybe try undoing the Bios change.
