Thedude81401
Oct 10, 2021Aspirant
New device
How Do You Turn It On? There Is No Power Button
Oct 10, 2021Guru - Experienced User
It should be just literally plug it in. If its got power, its on.
schumaku
Power LED indication?
- Thedude81401Oct 11, 2021Aspirant
I have it pluged in and no ligjhts at all are on
- plemansOct 11, 2021Guru - Experienced User
Check your power supply to see if its putting out the required voltage
I have tried several plugs, everything else workes in the ones i have tried
