Justgearnet
Jul 25, 2021Aspirant
New XS505M strange network reactions like paket losses
Hi there, before I return the newly bought XS505M I wanted to check the community if I can do something like a hard reset or similar. I used the Netgear switch now about 5 days, as an upgrade fro...
schumaku
Jul 25, 2021Guru - Experienced User
Start a test, run the similar ping from your QNAP NAS (from the NAS Linux shell) to the Internet .... if there should be a switch issue, you would see the similar ping failures. Also run this simple ping test from the QNAP NAS to the Windows 10 system. This should give you a better idea whee things are going bullocks.
Nothing to reset on the XS505M/XS508M switches, as nothing to configure, and not user loadable firmware.
