Justgearnet
Jul 25, 2021Aspirant
New XS505M strange network reactions like paket losses
Hi there, before I return the newly bought XS505M I wanted to check the community if I can do something like a hard reset or similar. I used the Netgear switch now about 5 days, as an upgrade fro...
Justgearnet
Ok thank you, if i ping from WLAN Smartphone to my PC I get sometimes drop outs.
I will return the switch as it is not working as a set and forget for me, sadly.
schumaku
Jul 25, 2021Guru - Experienced User
Exclude your PC from the test - most likely the issue you experience isn't switch related .... as long as you check with that very same PC you don't know where the problem is. That's why I suggested NAS and Internet, or NAS to router.
Leaving alone broken hardware, I've rarely seen a switch causing a problem as you have documented here. Focus on cabling, 10G/MultiGig adapter/driver or misconfigured adapter. Abd again, if there is a problem with one device take that one out of the test....
In case this undefined Asus 10G adapter is one of these well known Aquantia devices (now owned by Marvell), head to https://www.marvell.com/support/downloads.html for the current Windows drivers (search based on the chip model, like AQN-107 for example. These adapters have a long list of history with issues as you describe....
