Famoej
Nov 27, 2022Aspirant
No internet with switch
COnnected two ways first i ran my cat cable to the switch to my av preamp, nas,mesh. my av has lan ports all used. switch blinked as if signal was coming and going but nothing worked. I then ran...
Famoej
From router to mesh. Mesh Ethernet cable to wall to other side of house . Lan cable to switch routed to other devices. All light flickering but no service.
Unplugged and reverted back at which point it all worked again. I am just short on connections
schumaku
Nov 27, 2022Guru - Experienced User
Make a schema or put up a list with all the devices.
Mesh ethernet cable does read weird.
- schumakuNov 27, 2022Guru - Experienced User
Adding a switch e.g. to a common router LAN port is in general trouble-free, so one can connect more devices there, or even trunk to another switch.
