airj1012
Jan 23, 2022Tutor
PoE Network Switch?
I have a panel containing all my ethernet runs to my entire house. I'm going to add a network switch to this panel to facilitate the internet getting to all the rooms. There is not a plug within the ...
schumaku
Jan 23, 2022Guru - Experienced User
airj1012 wrote:
Sounds like I would plug in a PoE switch into my router. And then connect the GS108Tv3 with the PoE switch. The GS108Tv3 would get it's power from the PoE switch and not need an additional power source. Did I follow correctly?
Correct.
airj1012 wrote:
Is there a certain PoE switch that I would need to power the GS108Tv3? Extremely light understanding but PoEs have different port power ratings?
The GS108Tv3 does require plain standard IEEE 802.3af PoE. A IEEE 802.3af PoE or a IEEE 802.3at PoE+ power injector is perfectly sufficient (about 20 USD including power supply), unless you need a switch with more LAN ports near the router anyway. Watch your step - don't buy any of these passive or proprietary models.
airj1012
Jan 23, 2022Tutor
Thanks a LOT for the help. All this stuff is over my head, but I think I'm tracking. It's a pain that I can't ask Netgear directly. You'd think they'd help sell their own products...
Actually I do need a few more ports next to my router. Maybe a 5 port switch there would be helpful? Any that you recommend that you be able to power the GS108Tv3 further down the chain?
Thanks again!
