Ema1771's avatar
Ema1771
Follower
Aug 26, 2022
Power connector size for GS108 switch
Due to space constraints, I need to use a 90 degree adapter to connect the power to the new GS108 I just bought.  The easiest solution is to get something like this adapter but I'm not sure the exact size.  I've measured the outside diameter of the power plug, it's 5.5mm, so it's almost certainly either 5.5mmx2.1mm or 5.5mmx2.5mm.  However I'd like to know for certain which one before I try and order something.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Ema1771,
    Welcome to the community! 🙂
    The Barrel Plug Diameter for the GS108 switch are:
    Outside Diameter: 5.5mm
    Inside Diameter: 2.1mm
    DaneA
    NETGEAR Community Team
