vokster
Aug 13, 2020Aspirant
Pro Safe FS116P causing the router to act wonky
I have a set of 11 IP cameras set up in a remote location in the Caribbean. I have an Huwai LTE modem connected to a Nighthawk X6 router. I have a prosafe FS116P 16 port unmanaged switch connected ...
- Aug 17, 2020
Welcome to our community! :)
It seems that you were having issues with the FS116P. This switch is just unmanaged, so probably, there are loops in your network that causes for the router to stop working. Please double-check the cables if there are loops within your network.
We can only do a hardware check and isolation in order for this to resolve as we do not have anything to do with the switch.
John
NETGEAR Community Team
JohnC_V
Aug 17, 2020NETGEAR Employee Retired
John
- voksterAug 21, 2020Aspirant
I'm not personally on site, but when I phoned them, I asked them to follow each cable route, we found a network loop. Wasn't there when I set it up, was now. Thank you for your help.
