Victorgo's avatar
Victorgo
Product registration for XS708E
Hi Netgear support team,
I was trying to register for my XS708E. However, when I keyed in my serial no. it says that the switch has already been registered. Why? Am I getting something that has been returned to Amazon and resold to me?
How will I be getting my support on this product in future?
Victor
  • HI Victorgo,
    Just send us a PM so we can check. You may also want to follow mdgm's advice.
    Kind regards,
    BrianL
    NETGEAR Community Team
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I have moved your post out of the ReadyNAS section to here. The XS708E is not a ReadyNAS, it is a switch.
    It could well be that you bought an Amazon return if you bought it from there.
    The warranty is for the original purchaser only when purchasing from an authorised reseller. If Amazon sold you a second hand unit as new you should take that up with them.
    • Victorgo's avatar
      Victorgo
      Would you be able to help me check who is this switch registered to? I will need some evident that this switch is not a new unit.
      • Victorgo's avatar
        Victorgo
        Let me know where can I post my serial no. to help me check?
ProSupport for Business
