asimons67
Aug 04, 2021Aspirant
ProsSafe JGS524PE POE Not Working with SRC60
When connecting the POE switch to the APs using POE from the switch it will not connect to the main router when I use the power supply for the APs it connects fine. Latest firmware on the POE switch a...
- Aug 06, 2021
The SRC60 PD does strictly require an 802.11at (PoE+) capable PSE - the JGS524PE does only offer 802.11af (PoE). That's why the PoE handshake never succeeds, and the switch can't provide power.
schumaku
Aug 06, 2021Guru - Experienced User
asimons67
Aug 06, 2021Aspirant
That would explain it.
Thanks so much!
Thanks so much!
