cdmiller
Jun 19, 2017Aspirant
Can't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
Today I received a security alert from Netgear about older verions of Prosafe. So, I went online to check out my version. While I was on the latest version of Prosafe, I saw that I was not using th...
- Jun 19, 2017
HI cdmiller,
Could you let us know which switch model do you have ?
The latest ProSafe version that we have it's the 2.4.3 and you can download from :
https://kb.netgear.com/000037852/ProSAFE-Plus-Configuration-Utility-v2-4-3
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Jun 19, 2017NETGEAR Employee Retired
HI cdmiller,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
cdmiller
Jun 21, 2017Aspirant
Upgrading to Prosafe 2.4.3 resolved this problem. I should have tried that first. I can no login successfully from the utility. Thank you for your help.
