othni
Nov 02, 2016Aspirant
GS105e can not login or factory reset
I have a couple GS105E switches at work. I am using the latest ProSafe Utility version 2.3.20 to access them. The switches show up in the utility, but do not accept any password (or blank) to c...
- Nov 10, 2016
Hi othni,
We get the information: FW v3.01.28 is an official release for TOTALPLAY, which is customized product.
The default setting difference was requested from TOTALPLAY, so TOTALPLAY should know the default password is not “password”.
Please contact Totalplay directly because of only Totalplay know the password. :smileyhappy:
Thanks for JohnRo’s help, too.
NETGEAR Employee
JohnRo
Nov 08, 2016NETGEAR Employee Retired
Hi othni,
I'd like to know if you were able to login to the switches? Did any of the suggestions work?
Thanks,
othni
Nov 08, 2016Aspirant
No, I have not been able to login.
There has been a couple of private messages from ElaineP but mainly to provide additional information and screenshots.
There has not been a suggestion that I already tried or that was possible to do.
My original post is where I stand with this.
