othni
Nov 02, 2016Aspirant
GS105e can not login or factory reset
I have a couple GS105E switches at work. I am using the latest ProSafe Utility version 2.3.20 to access them. The switches show up in the utility, but do not accept any password (or blank) to c...
- Nov 10, 2016
Hi othni,
We get the information: FW v3.01.28 is an official release for TOTALPLAY, which is customized product.
The default setting difference was requested from TOTALPLAY, so TOTALPLAY should know the default password is not “password”.
Please contact Totalplay directly because of only Totalplay know the password. :smileyhappy:
Thanks for JohnRo’s help, too.
NETGEAR Employee
JohnRo
Nov 09, 2016NETGEAR Employee Retired
Hi othni,
Were you able to login to these switches before? If so, was the password ever changed?
Thanks,
othni
Nov 10, 2016Aspirant
These switches have only been accesible to me for less than two weeks. I asked around but nobody can tell me if the password was changed. I only got the response to use the default password. So I don't think these switches were modified. Anyway, after the 99 times I have pressed the reset button, it should not matter anyway.
ElaineP is trying to help me. She sent me some private messages.
- JohnRoNov 10, 2016NETGEAR Employee Retired
Hi othni,
Okay, got it. I was just making sure that you were able to access them before using "password" as the password. Kindly update the thread just in case.
Thanks,
- ElainePNov 10, 2016NETGEAR Expert
Hi othni,
NETGEAR Employee
- othniNov 11, 2016Aspirant
This makes sense now!
I am not familiar with TotalPlay...do you have a website or information about them?
Thank you!
- othniNov 14, 2016Aspirant
Thank you for all your help!
