BDT907's avatar
BDT907
GS105v5 mounting
I need to mount the GS105v5 to a DIN 3 (35mm) rail at 90 degrees, such that the power adapter will plug in at the "bottom" and the Ethernet cables will plug in at the "top". Any tips for how best to ...
  • Marc_V's avatar
    Nov 01, 2022
    BDT907
    The switch should have wall mount kit included where you can install the switch at an angle where the Eth ports are facing down or up but if you plan on mounting it on a rail you may want to check custom mounts that are 3D printed like this.
    HTH
ProSupport for Business
