ahmedt
Apr 17, 2017Aspirant
GS108v4 no connections to device
Issue: There are no connections for the devices if I connect through the switch. Setup attempts: 1. Internet -> Sky Q modem/router1 - GS108 - direct cat5 cable to desktop or Huw bridge O...
- Apr 20, 2017I read one of the other thread. The connection between the switch and the router needs to use cat5e above cable. I am using a new cable which has 6 or more wires and it works.
ahmedt
Apr 18, 2017Aspirant
Will try. How do I restore the default configurations you mentioned in point 2.
