Sylwedydd's avatar
Sylwedydd
Model Identification of JGS524 Series Switch
Hello,   I have decided on the JS524 Switch for my network. In my pursuit I have seen a Model JGS524 V1. On your site there is no reference to it, only the JGS524 V2. Is the V1 a "knockoff" or mere...
  • DaneA's avatar
    DaneA
    Jan 05, 2017
    Sylwedydd,
    I did a research about the JGS524v1 data sheet online.  If ever you are still curious about it, you can download it here and you can also view it here.
    For the JGS524v2 data sheet, you can download it here.
    Here is a quick view of the differences between JGS524v1 and JGS524v2:
    From the table above, it is advisable that you get the JGS524v2 instead of the JGS524v1.
    DaneA
    NETGEAR Community Team
