dsum
Mar 27, 2017Aspirant
Statement of Volatility for GS108v1
I am looking for a statement of volatility for the GS108v1 8 port ethernet switch. Thank you!
DaneA
Apr 02, 2017NETGEAR Employee Retired
dsum,
I just want to follow-up on this. Were you able to download the letter of volatility for the GS108v1 switch?
If ever you were able to download it, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
dsum
Apr 03, 2017Aspirant
This was exactly what I was looking for and I was able ot download it. Thank you!
- DaneAApr 03, 2017NETGEAR Employee Retired
Thanks for the feedback. I'm glad to know that you were able to download the letter of volatility for the GS108v1 switch. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
