mmitsch
Mar 19, 2018Tutor
What switch to buy?
I have a Netgear R8000 Nighthawk X6 AC3200 Tri-Band WiFi Wireless Router and a Netgear CM700-100NAS Cable Modem. An insatller is setting up my home network and he said he needs me to get a 16 port s...
DaneA
Mar 21, 2018NETGEAR Employee Retired
Hi mmitsch,
Both the GS316 and GS116 switches are unmanaged, pass-through switches. Their main purpose is to extend your local network in order to connect more networking devices such as PCs, network printers, etc. Check the table below which shows some differences between the GS316 and GS116v2 switches:
Note: The latest version of the GS116 switch is the GS116v2 (v = version).
The GSS116E is a web managed click switch which gives user the flexibility to configure certain static layer 2 settings in order to improve network efficiency and performance. The configurable features are Port Mirroring, VLAN, QoS, Rate Limit, and Broadcast Storm Filtering.
Note The suffix NA or 100NAS at the end of the product model (example: GSS116E-100NAS or GS116NA) is the product order code in North America.
For more information, kindly access their respective data sheets below:
If I were to choose, since all of your existing devices are NETGEAR SOHO Devices (R8000 Nighthawk X6 AC3200 Tri-Band WiFi Wireless Router & CM700-100NAS Cable Modem), I would select the GS316 switch which is a NETGEAR SOHO switch.
SOHO = Small Office Home Office
DaneA
NETGEAR Community Team
mmitsch
Mar 26, 2018Tutor
I bought the GS116NA but think maybe I should take back & get the 316 based on your advice.
Thanks for the help & let me know what you think.
- DaneAMar 27, 2018NETGEAR Employee Retired
Having the GS116 switch in your existing network is just alright. :)
Reagrds,
DaneA
- mmitschMar 27, 2018Tutor
You mean by just alright that it'll be ok? The insatller guy put it it but, if I should switch, I will.
And thanks for the advice!
Mike
