wiz01
Jun 07, 2019Aspirant
Replacement JGS524v1 power cord
Hi, I have a JGS524 24 Port Gigabit Switch and I lost the power cord. I am trying to buy a replacement but am having no luck. Specs under the socket say 100-240V 50-60Hz 1.0A max. Thanks
- Jun 07, 2019
Aehm, that's a switch with a built-in power supply ... any standard power cable as used for PCs and the like with a IEC 60320 C13 female plug and whatever you need at the wall outlet side will do the job.
schumaku
Jun 07, 2019Guru - Experienced User
wiz01
That's great news! Thank you for the help
