Wolfangovich's avatar
Wolfangovich
R6300 Power Adapter replacement?
For a replacement power adapter, I understand it is a 12V 5a, but what is the polarity on the end? Is it Negative inside or Positive inside?
TIA.
    A quick check of four Netgear adapters I have lying around says positive inside.
  • > [...] I understand it is a 12V 5a, [...]
       For an R6300 plain/v1, that seems to agree with the documentation.
    (The R6300v2 seems to be more efficient.)
    > [...] what is the polarity on the end? [...]
       Doesn't the label on the adapter show this?  If not, then look
    closely at the product label on the router  If that fails, then visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Label".  (Also
    interesting: "Technical Specifications".)
    • Wolfangovich's avatar
      Wolfangovich
      1 I checked all documentation
      2 little hard to check the adapter if I am replacing it
      3 the router does not show this information, thus the question in the first place
      4 checked their entire site, answer is not found on there, thus the question
      • michaelkenward's avatar
        michaelkenward
        Look on the back? That's what I did.
    michaelkenward
