Ian1976
Apr 19, 2016Aspirant
Replacement switch
Hopefully an easy question! We're a small shop with two adjoining buildings. We currently have an FS108 switch in each - with the two switches linked by cable. In one building we want to incr...
- Apr 19, 2016
Hi Ian1976,
You're welcome! :) Nice to know you've already ordered the GS116v2 switch.
Since your concern is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!Cheers,DaneA
NETGEAR Community Team
Ian1976
Thanks for the reply Dane. I've just ordered up the GS116v2 as indicated.
Cheers, Ian
DaneA
Apr 19, 2016NETGEAR Employee Retired
Hi Ian1976,
Cheers,
DaneA
