mringerud's avatar
mringerud
Follower
Jan 16, 2018
Request for Letter of Volatility for JGS516
I need a Letter of Volatility for a JGS516 16-port Gigabit Switch so we can use the unmanaged switch in our lab. All the links in the other similar posts were expired.   Thanks! Mark
  • JohnC_V's avatar
    Jan 16, 2018
    Hi mringerud,
    Welcome to our community!
    Here is the latest certificate of volatility for JGS516. The link will expire after 48 hr period. No password needed.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
