K3UK
May 17, 2023Follower
Second device GS305 does not work
I just installed a Netgear GS305 switch to provide additional Ethernet service to two devices in a room . The first device plugged in works as expected , the second device does not, no quick blinking ...
May 17, 2023Guru - Experienced User
Does it work if you connect it directly to your router?
What router do you have?
