daikon
May 29, 2024Follower
Smaller power adapter options for GSP316PP
Hi,
I am looking for smaller power adapter options for the GS316PP.
Are there any Netgear compatible power adapters I can use that have a smaller form factor than the one included in the box? (Netgear adapter with model no. KPM200R-VI)
Thank you
The GS316PP does come with a 200 W power supply (EPS200W). For lower PoE power requirement, you can use the EPS130W or EPS90W. Once upon a time, Netgear offered a EPS67.5W model, too.
Whatever is smaller - never seen a formal physical size information.
The KPM200R-VI is a typical OEM power supply model delivered under the EPS200W SKU.
External Adapter Model EPS90W, EPS200W, and EPS200W Installation Guide
This is what is available and officially compatible and supported by Netgear. Have fun to find some physically smaller 54V power supplies
1 Reply
